i need help
elky1349
i need help
Post by elky1349 »
i fixed the tss and when i go to bolt the colum up there are some sparks and the left side quites any hep i need to get this truck going thanks for any help here :x
Re: i need help
the left side. inside the column? what quites?
elky1349
Re: i need help
Post by elky1349 »
he left turn does not work when i bolt the colume up the bolts have sparksand then i tighted em up u can hear it blink the back one work not the front
m-mman
Re: i need help
Post by m-mman »
You have pinched the TSS wires between the shift collar and the steering column (mast jacket) :oops:
You need to pull it all apart again and make sure the wires are threaded into their tunnel in the mast jacket and are free to move easily when the top plate is attached and seated to the shift collar.
BTW- you may find that you have CUT the wires and they would need VERY CAREFUL splicing. There is not much room in this area and using a crimp connector will most likely jam things up.
You MIGHT find yourself needing another whole TSS. :cry:
1969 F-100 Custom Cab 302 T-85 Overdrive, 3.70 equalock & factory 16" wheels
