Insulating the headliner?
What do you guys use to insulate the headliner? Also, do you stick it to the roof or on top of the headliner?
Re: Insulating the headliner?
EDIT: i have never ever seen insulation above a headliner. rats must have eaten all of it away. i have seen once some glue liek substance on the roof of one of these trucks i have parted out.
- 1971ford
Mine had puffy sound deadener stuff (you know the greenish stuff with color flakes, reminds me of stuff under carpets) glued to the roof.
I am going to put the dynomat (or whatever brand) covering the whole roof area instead. Then maybe some of that puffy stuff that was on their originally, because rain is pretty loud on our thin metal roofs
-Ryan
I bought a large sheet of foam insulation from Lowes/Home Depot, cut it to fit, and then stuck it to the roof. Since I put speakers in the headliner, I wanted something between the speakers and the roof, and the foam insulation was the perfect, inexpensive solution. It made the speakers sound better too
1970 F250 Camper Special
I used the shiny stuff from Lowes also but used a spray on glue. Made a lot of difference in the sound. Mine had nothing in there from the factory
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
1971ford wrote:Mine had puffy sound deadener stuff (you know the greenish stuff with color flakes, reminds me of stuff under carpets) glued to the roof.
Mine also, Green puffy junk glued to the roof. my headliner is gone but this stuff is still hanging in there, i think i will replace it with Dynomat also.
1970 F100 Ranger XLT SWB 302
2004 Nissan Murano
1998 Isuzu Amigo "v6 4x4 conversion comin soon"
2004 Nissan Murano
I havent tried this yet but am going to this weekend. My cab has a few small cancer spots arounf the drip rails. I was thinking about injecting this open space between the external roof and internal roof with that expanding foam stuff. Any thoughts on that. I will only be doing this to my 71 as it has a hole large enough to accept the nozle fromthe foam can.
What do you guys think?
I havent done anything to my 68 yet.
Russ Stanley
68 F250 ( ol' Grand Dad)
71 F100.( Old Blue)
65 Valiant Wagon (Gone but not forgotten)
2007 PowerStroke(The Golden Goose)
71 F100.( Old Blue)
- knightfire83
68_250 wrote:I havent tried this yet but am going to this weekend. My cab has a few small cancer spots arounf the drip rails. I was thinking about injecting this open space between the external roof and internal roof with that expanding foam stuff. Any thoughts on that. I will only be doing this to my 71 as it has a hole large enough to accept the nozle fromthe foam can.
If your not going to fix the rusted thru cancer spots the foam will likely not seal 100%, and the area will hold moisture. From there the rust will accelerate.
![2 cents :2cents:](./images/smilies/icon_2cents.gif)
1970 Ford F250 4x4 ~ Sold.
- 67nukeford
If you do that, make sure you get the foam that is the low expansion. The normal stuff has unbelievable pressure when it expands, and you don't want it pushing something out of shape!68_250 wrote:I havent tried this yet but am going to this weekend. My cab has a few small cancer spots arounf the drip rails. I was thinking about injecting this open space between the external roof and internal roof with that expanding foam stuff. Any thoughts on that. I will only be doing this to my 71 as it has a hole large enough to accept the nozle fromthe foam can.
