#50's bench done with a foam base and bright yellow vinyl!
fireguywtc
Re: #50's bench done with a foam base and bright yellow vinyl!
Post by fireguywtc »
WOW that is bright!
Bill
papabug71
Post by papabug71 »
Awsome. Thats alot of coin for a re-covered seat, but im willing to say its a one of a kind just like you said !!!
It will get alot of attention, thats for sure :)
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
i was thinking you may have had it done in black and yellow accents in the center sections. but i guessed wrong. i am thinking that price is out of line.
robroy
Post by robroy »
Hey Fordman, thanks for replying!
I see your point! Yeah it was a lot to spend, but I love the results. Maybe if I'd had more time to investigate alternatives I could have found a better way, but at the time, I was working a super demanding software engineering job with long hours. Looking back, I'm amazed that I managed to make progress on this at all! I don't think I slept much.
Thanks again Fordman!
Robroy
brandon.k
Post by brandon.k »
Thats pretty kool. The outside edges of my seat is the same yellow. :lol:
robroy
Post by robroy »
Hey Brandon, thanks! Do you happen to have a photo of your seat on here? I'd be curious to see how that looks, with the outside edges that yellow.
Thanks Brandon!
Robroy
Happy_Camper
Post by Happy_Camper »
Looks like they did awesome work! :thup:
One of the big things I like about a "mono-color" smooth cover like you've done, is that down the road it can be easily modified.
For instance, after a few years if you tire of it, you could go back in and have them sew on a checkerboard panel, across the top and bottom edge, or down the center. Or they could add a differnt color insert pair with pleats or something.
Doing it the way you did, leaves lots of options, if you decide to make a change down the road.
I'll bet it's really comfortable.
Pretty cool amigo! :hd:
Scott
1972 F250 Explorer C/S, 390-2V, Dual exhaust, C6, Goose neck ball in bed
New and improved with Tilt Wheel, Intermittent Wipers, 2005 Bench seat and 5th wheel camper!...
Life is *very* good!
brandon.k
Post by brandon.k »
Here's a couple Robroy. The vinyl is starting to crack but it was all done for my high school graduation present in 1988. For the most part its holding up pretty well.
