stuck choke cable
stuck choke cable
i have a choke type cable from a older truck. is is rusted stuck. i have been spraying pb blaster down from the top of it so it would run down into the cable while i have it hanging up. but nothing much seems to be happening. the cable has a rubber coating on the outside so i really can put any heat to it. any other sugjestions?
fireguywtc
Re: stuck choke cable
Post by fireguywtc »
I would try curling it up in an old coffee can filled with gas or diesel and let it soak.
Bill
papabug71
Post by papabug71 »
fireguywtc wrote:I would try curling it up in an old coffee can filled with gas or diesel and let it soak.
:yt:
Exactly what I was going to say. For some reason gas works better for me than diesel.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
it has a rubber coating. i dont think it would work very well. but it could seep through from both ends i guess. i might try that.
TNIceWolf
Post by TNIceWolf »
It should work fordman. I freed up a parking brake cable of similar coated design by rigging it where it hung in a U shape and applied PB to both ends several times a day and tried to move the cable from both ends at each dosing a couple of times......it eventually caved in to my will and finances.
Presently in the stable
1969 Ford F-350 DRW
Fastbackin1970
Post by Fastbackin1970 »
Hey Fordman let me check when I get home. I think I have a new choke cable from LMC you can have.
1970 Ford Boss 302
1972 Ford F100
Old Fords are like fine wine, they just keep getting better with age.
it isnt a choke cable and i dont need it. it is a different cable and if i get it unstuck i can ebay it. i have two good extra stock choke cables in my stash. so i dont need any more. thanks for the offer though.
