quik question
austin
quik question
Post by austin »
does anyone know if the door seal plates came stock on all bumps?
my dad seems to think they did and i have no clue :?
1971ford
Re: quik question
Post by 1971ford »
the aluminum plates that run along the weatherstripping, that also hold the carpet down? Yes those are on all bumps.
-Ryan
Re: quik question
yes they came on all trucks. to hold down the carpet or mat. plus they aslo hold the door rubber ends on. that is where they meet is under the sill plate.
austin
Re: quik question
Post by austin »
yup those are the plates im talking about mine are missing and a big chunck of weatherstripping is gone to i guess i will look for some new ones and some new weatherstripping too
thank you
flyboy2610
Re: quik question
Post by flyboy2610 »
LMC has them. That's where I got mine, and they fit just fine.
austin
Re: quik question
Post by austin »
okay would dent side sill plates fit? i have a set out my 73
Re: quik question
yes they will fit. the only real difference is where they come up the kick panel. the dentside ones dont go up as far as are do. so the screw hole in hte kick panel will still be showing if you use the dentside plates.
austin
Re: quik question
Post by austin »
thank you i will have to pull them plates :D :fr:
austin
Re: quik question
Post by austin »
pulled the plates they fit perfect i going to polish them up a bit and install them for good
