throttle cable set for efi?
i have a 69 f100 2wd swb with a 460 that had a carb but im changing it to efi with standalone ecu and edelbrocks carb to throttle body adapter elbow, now heres the problem the mustang TB and elbow is on the passanger side and is cable. i know that you can get the half rod half cable pedal from the 79 f100 but that still wont work for me because of everything being on the wrong side, so i want to go to a complete cable set up.
- knightfire83
Re: throttle cable set for efi?
Summit and I assume Jegs has universal cables in various lengths you could use with the '79 pedal assembly. Or you could go junk yarding to search out an appropriately sized cable.
http://www.summitracing.com/search/Part ... ttle+cable
1970 Ford F250 4x4 ~ Sold.
but the cable will rub on the elbow that holds the throttle body. im probably going to make the 1980 assembly work it looks like all i would have to do is drill 4 holes and maybe use some washers to get the spacing right.
- zakt
putting an EFI 460 in my truck out of a 95 F350 and am using the foot pedal out of the same truck (swaping foot pedals) I believe our pedals push but need a pull pedal for the EFI throttle cable.
Todd
Todd
1972 Ford F350 crewcab
![Image](http://www.fordification.com/galleries/albums/userpics/10045/350emblem~1.jpg)
- basketcase0302
bbfhnj,
http://www.fordification.com/forum/view ... 53#p433753
Here's the minor differences in the bump vs. the dent pedal assembly:i know that you can get the half rod half cable pedal from the 79 f100 but that still wont work for me because of everything being on the wrong side,
- BobbyFord
What trans are you running?
