New addtion to 72 F100 interior
03svtsnakevert
Post by 03svtsnakevert »
Well, I pulled the trigger and purchased a dakota digital gauge cluster for my 72...I can't tell you how much of a difference this makes to the all out cool factor for the truck...Not to mention it will measure 0-60, 1/4 et and MPH and top MPH..WILD!! I have attached a couple of pictures...the install was not that difficult either...enjoy!! Also got a new woodgrain bezel and lens for Christmas....
My truck:
New bezel with cluster:
Instrument Cluster:
Last edited by 03svtsnakevert on Fri Mar 19, 2010 11:33 am, edited 1 time in total.
Doug Comer
Re: New addtion to 72 F100 interior
Post by Doug Comer »
8) Pretty cool. What's next?
Doug
1967 f100 4x4
1970 f250 4x4
03svtsnakevert
Doug Comer wrote:8) Pretty cool. What's next?
Doug
Well, I also got a the vinyl for the bench seat..I am going to finish painting the interior...new carpet, update the A/C...gonna paint the truck hot rod black...remove all the molding and have a smal red and cream pin stripe painted down the side lowered with DJM's kit and some torq thrust TTOs...then more mods to the motor..3x2 setup, different heads
Doug Comer
Sound like your gonna be busy. Good looking truck.
Doug
1967 f100 4x4
1970 f250 4x4
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Is the fuel gauge configured to use the stock sending unit? I'm asking 'cause it looks like your fuel gauge is reading '67 gallons'. :lol: (or is that supposed to be 6.7 gallons?)
It's looking good! I like it...and the whole truck in general. Nice stance. :thup:
70_F100
Post by 70_F100 »
FORDification wrote:Is the fuel gauge configured to use the stock sending unit? I'm asking 'cause it looks like your fuel gauge is reading '67 gallons'. :lol: (or is that supposed to be 6.7 gallons?)
I wondered about that, too, when I first looked at it. :hmm:
My guess would be that's 67%. :thup:
03svtsnakevert
Yes, that is correct...you can select pretty much any sending unit you want for the setup when you turn it on...you go through some setup screens with it and all you have to do is select the proper sending unit that you have...very cool setup...and yes, it is 67%
Thanks guys!!
ToughOldFord
Post by ToughOldFord »
Looks good! :thup:
Caseys71
Post by Caseys71 »
Those gauges look great, nice that your still using the original bezel as well it really looks good :thup:. They definitely look and probably work better than my non-working gauges :lol:, how much did they run you?
Casey
papabug71
Post by papabug71 »
I like it. I wish I had another truck to build up into a hot rod. The digital gauges would be the first order of buisness on the interior.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
03svtsnakevert
Caseys71 wrote:Those gauges look great, nice that your still using the original bezel as well it really looks good :thup:. They definitely look and probably work better than my non-working gauges :lol:, how much did they run you?
These were 620.00, however I could make you a great deal on the working cluster I pulled from the truck...
1971ford
Post by 1971ford »
Wait... that cluster is nice and all but seems it will be way too depressing. I have found that the stock fuel gauges are built by Ford to be innacurate, and have a small sweep so they barely need to move... making it nice not being able to see your fuel gauge drop while driving :D . However, when you have an accurate, modern percentage gauge, you will see that thing drop a percent or two every second... which will be very depressing :eek:
I'll stick with my no gas gauge... it seems to help not being able to see my needle drop :thup:
But really that thing is way nice :eek:
-Ryan
JMcTurnan
Post by JMcTurnan »
I found it, but extremely expensive. Did it hook right up?
91Bear
Post by 91Bear »
Speaking of fuel gauges, why does mine read 3/4 full when I fill it up and then goes to full after I drive it around for awhile?
JMcTurnan
Post by JMcTurnan »
Sometimes there is air in the tank that compress it down. Faulty sending unit, many things could be wrong. Does yours have a emissions port?
