another ignition switch question
- randyvines
The blade connector on the side of the switch gives a momentary ground to the case when in the start position... what is connected to this I haven't found a thing that this does on the diagrams. Make me go hmm?
- randyvines
Re: another ignition switch question
Yes a 67 f100
possible momentary ground to dash warning lights? Ground to turn the lights on (momentarily) while cranking to let you know they work.
- knightfire83
It is for the brake warning light along with the oil and temp warning lights on the dash. (If so equipped)
This allows you to see if they are functioning and not burned out when you go to start up.
1970 Ford F250 4x4 ~ Sold.
- randyvines
what an incredible night; ignition switch replaced and dash lights fixed (corrosion on rheostat) makes for a huge mental step.
