A/C fan problem
fireguywtc
A/C fan problem
Post by fireguywtc »
My 70 with A/C only works one speed for the Fan, High. Before I pull the whole unit out for repair I want to make sure I am on the right track. I did some searching and it looks like it is most likely the switch that is the culprit. Then fan works on high, though noisy, and I put a resistor in from a spare unit I have and it didn't change. Both resistors appear to be fine but I though I would try the simple fix first. It has a 3 speed fan, when I move the switch from high to med, it sould like it runs for a second or two then dies out, never does anything in low. Thanks for the help
Bill
1970 F-250 4x4 highboy ranger 390 V8, 4spd
2012 F-350 PSD FX4 LWB CC lariat, white
http://www.fordification.com/galleries/ ... hp?uid=602
"If you want to judge a person's true character, give them power."
Dragon
Re: A/C fan problem
Post by Dragon »
Switch can be tested by running a hot jumper to a resistor terminal on the heater and seeing if it runs at a lower speed.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away. :)
My Gallery
Spark test
