Bronco Graveyard
- basketcase0302
Bronco Graveyard
Hey guys (and gals),
I know most of you might not ever use them, but once again I have to give "Jeff's Bronco Graveyard" a thumbs up for a recent order I made with them:
http://www.fordification.com/forum/view ... 1&start=75
I'll use the oil pan "screw-in" dipstick on my "little 302's" 4 X 4 oil pan rather than the timing cover oil dipstick.
Our trucks "little brother" the Bronco does share quite a few things with our trucks, that might be of some help to some of you. Jeff's is in Michigan (Ted Nugent and Chip Foose are two of their customers) and my orders the past 20 years or so have always arrived quickly and correct.
Everytime I wear my "Jeff's Bronco Graveyard" hat I get questioned
It seems they no longer sell the hats...
http://broncograveyard.com/
- HOWDY69
Re: Bronco Graveyard
I bought a foam kit from them when I replaced my heater core. No rattles.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
I have to totally agree. I drove to their store and they have some cool bronco's in a room off to the side, there is even a bronco frame just off to the left when you walk in there. I will be buying a diff. locker from them. They also have a ton of old bronco pictures in their store, and they have a classifieds section on their website for all over the country. Then they have a show every year, I haven't been to it....yet. Their prices are very low and they have parts that most of the other companies don't carry.
Justin
http://www.fordification.com/forum/view ... 22&t=47482
http://s976.photobucket.com/home/bb429power/allalbums go to both of the albums.
1967 Ford F100 longbed with a 466 500+hp/600+ft-lbs (mine)
1969 Mercury Cougar xr7 with a 351w (dads, I helped alot)
1970 Ford Maverick with a 302 (became our drag car)
1986 f150 5.0 (my DD)
"Many can argue, but it takes a real man to apologize."-Me
- Doug F
I plan on buying a lot from them soon... I have a "Dent" front axle that I am rebuilding and they have a bearing and seal kit that is everything except the R&P for $255! I will be buying my Calipers, Hubs and Rotors from Rock Auto though, because I can see what brand and quality they are. But Jeff's has great pricing on his R&Ps too!
Also look up BC Broncos, they have a strut arm set-up that looks incredible for our trucks!
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
http://www.pinheadlounge.com/Pinecone
https://www.facebook.com/PineconeDesign
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
- eggman918
I bought all the parts for my closed knuckle 44 and then decided to upgrade a disc 44.they took my returned parts with no complaint or restocking fee,even though it was my mistake.
There shipping is fast and there service is first rate.
Steve
My two cents...beware of their catalogs, online or paper. Under the 3/4 Ton Dana 44 applications, they have parts that will only fit 1/2 tons or Broncos. Specifically, on the website is a Dana 44 master overhaul kit for a hub to hub overhaul of the Dana 44 that is under the 3/4 ton application page specific, but when you investigate it a bit, all the wheel bearings, hub seals, etc are for a F150. I just spoke to them about that and pointed out that it is mislabelled, but if you just ran with it and clicked, you would get the incorrect parts for your 3/4 ton.
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
- 1972hiboy
I have used them to get wiper seal kits for my big ball closd knuckle 44. I was happy with the parts and ther service.
Rich
Dont eat yellow snow.....
- 1970 Hi-Boy
- Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
They are a good source for Polyurethane Transfer case mounts. I ordered a set from them for my Dana 24 and they worked great, the old rubber ones were really shot!
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
Was just at their store today to pick up some heavy duty motor mounts, great quality at a fair price.
- basketcase0302
I've still got a ball cap here, (from the 70's) of the ORIGINAL "JEFF'S BRONCO GRAVEYARD"!
Loved getting a rise out of guys when I still wear it, "you own a Bronco graveyard Jeff"?!
They were always good folks to deal with and outstanding products!
https://broncograveyard.com/?msclkid=ef ... 0Graveyard
