seat upgrade
- bigredball90
seat upgrade
I want to upgrade to a newer seat up to 96. It needs to a bench with the consol that flips down. I would prefer buckets but I dont really want to drill more holes unless someones done them and its easier than it sounds. The catch with the bench seat is that I have a 5sp. as it is right now the very bottom of my shifter just barely touches the seat so it works great. What is the seat depth (the part you would sit on) on your newer seats?
no truck just a merkur...
Re: seat upgrade
i don't know right off hand abotu the depth of the bottom part of the seat. but i can tell you that to install bukcet seats all you need is to drill one hole per side fo reach bucket seat. so you will make two hole total. the rear hole is already there from the factory. it is under the square rubber plug.
- floyd67
Re: seat upgrade
these are my seats
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
2013 f-150 DD
- bigredball90
Re: seat upgrade
they look like they might sit to far forward for my shifter. Any measurements?
- flyboy2610
Re: seat upgrade
Do you know what those seats are out of?floyd67 wrote:these are my seats
Re: seat upgrade
Look nice in there but like said too far forward and the backs are too up right. I don't think I could be comfortable in them.
All of the later model Ford truck seats I have seen in a bump look about the same. I think our cabs are just not long enough for them. I actually had a set of original buckets at one time years ago and traded them for a set of wheels. I still kick myself about that. They looked right in a bump to me.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- GSequoia
Re: seat upgrade
From the photos I've seen the bump buckets aure look the same as my 1966 Mustang buckets, I'd have to see them side by side to be sure but you might want to consider that, a lot of Mustang guys put aftermarket seats in (I plan do to that as well). You'll still have to source brackets but I know that there are drawings of the OEM brackets so they can be recreated.cdeal28078 wrote:Look nice in there but like said too far forward and the backs are too up right. I don't think I could be comfortable in them.
clint
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
Re: seat upgrade
They looked a lot like early Bronco seat also. I bet they were used on many early cars.GSequoia wrote:From the photos I've seen the bump buckets aure look the same as my 1966 Mustang buckets, I'd have to see them side by side to be sure but you might want to consider that, a lot of Mustang guys put aftermarket seats in (I plan do to that as well). You'll still have to source brackets but I know that there are drawings of the OEM brackets so they can be recreated.cdeal28078 wrote:Look nice in there but like said too far forward and the backs are too up right. I don't think I could be comfortable in them.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- floyd67
Re: seat upgrade
they are out of a '96 f-150 xlt extended cab they fit in the same location as the factory bench but with home made brackets
1967 f1oo "floyd"
2013 f-150 DD
2013 f-150 DD
