Emergency flashers
3 Speed
Emergency flashers
Post by 3 Speed »
When my mechanic got my 67 road worthy last August, we fixed a turn signal. What we missed was this: The emergency flasher works all the corners except the front right, even though all the turn signals work.
What's with that?
67 F101 Custom Cab longbed, 352 V8, 3 speed manual
Re: Emergency flashers
i will check into the diagrams and see what i can see. and check back later.
Thunderfoot
Post by Thunderfoot »
The fronts Hazards are output from the Hazard switch itself, the output splices into the wire for the signal. You will see it is 2A in this diagram http://www.fordification.com/tech/wirin ... ghts02.jpg at the Emergency Warning Switch.
So either the switch is bad or the wire is open somewhere. More then likely the switch. :2cents:
Reason: Added diagram link
you can take those switches apart and clean them. just be careful not to loose the spring when you take it apart. if you do.
Mach428
Post by Mach428 »
Fordman is right - same thing with blower switches. I just took one apart in my Mustang last night because the blower wouldn't work continously on high. Took the switch apart and used a brass brush on the copper slider and contacts. Put some white lithium grease where the plastic slider contacts the base and put it all back together. Works perfectly
floyd67
Post by floyd67 »
i had the same problem different light though it was the switch
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
3 Speed
Post by 3 Speed »
Problem solved!
Thanks for the diagram. I just started at the switch and guess what I found -- a loose connection on "2A".
Good to go.
