seat repair parts
Old Bird
seat repair parts
Post by Old Bird »
I got a new seat cover from Mac's and have all the padding and burlap to redo the seats on my 68 Ranger. Unfortunately, when I got all of the old seat cover and padding material off, I found one of the coil springs on the driver's side is broken, split about 1/3 of the way down. I looked at Mac's and don't see any replacement springs or seat parts, does anyone know where I can get the coil springs?
The other part I don't have is one of the original bolts that goes from the seat back bracket to the seat bottom frame. I've got one (with the big hex-hed), but the other was replaced with a standard bolt and the chrome cover won't go back on. Any source for those?
Thanks!
Timothy
It's for my twin boys, sure they're only 3 right now, but it's all for them! Well, and my twin girls. They're not even 1 yet, but when they are I'll have a pit crew!
Toys:
62 Thunderbird Convertible
68 F250 Ranger 2wd - 390 C6
Caseys71
Re: seat repair parts
Post by Caseys71 »
As for the seat springs I'd ask around at your local interior shops, they may have some. As for the bolt I'd check out McMaster Carr they seem to have just about any fastener you could imagine :thup:!
Casey
lmc has the botls for the sides i didnt see the coil springs listed int he seat rebuild kit they offer. there is a seat out at the junkyard from a 79 with the coils and the botls still in it. i could get them for you if you need them. or mayeb someone else has them from a seat they arent going to use any more.
Old Bird
Post by Old Bird »
Thanks for the tips. I'll look at LMC.
I appreciate the offer for getting them from the junkyard, if you happen to be going there anyway they should be an easy thing to get. If you're not, let me see if I can get them locally first.
Timothy
Toys:
i got the bolts but the seat had been rebuilt and the original springs were gone. i did get a good slip cover for my 4wd seat.
Caseys71
Post by Caseys71 »
Actually I did remove a stock seat from my truck and I can pull a few springs from it. Let me know if you're interested, you can have them for the cost of shipping :thup:!
Casey
Old Bird
Post by Old Bird »
I love this place! I'll take you up on your offer, Casey, I'll PM you my info.
I ended up getting new bolts from LMC along with new chrome covers. May as well do it right the first time.
Timothy
Toys:
i knew someone would have them.
Old Bird
Post by Old Bird »
Thanks Casey for sending the springs! The seat has firmed up a bunch. It doesn't feel like new, but definitely a ton better than it used to be. I put on new canvas, foam and seat covers from Mac's, tied some springs together and replaced one broken spring with a spare that Casey had, and put new chrome covers from LMC on. It sure ain't perfect, but not bad for my first attempt. Total cost was about 3 bills. I'm sure a good shop could have done better for about twice that, but I'm happy knowing that I did it and the few hundred bones in my pocket should get me a nice new stereo for the truck.
Unfortunately, once I finally got the seat back in (it's been out about six months as I was trying to find the time to do the work), I wanted to take it for a spin around the block to see how the rebuilt seat felt. It started to fire up right away but never caught. Then it was turning over with no fire. I got out to check under the hood and instantly smelled gas. Under the hood there was fuel all over the intake manifold, it looks like my carb gaskets all dried out in the six months that it sat. Damn desert air! Time for a carb rebuild, I'm sure I'll be able to finish that in the next six months too . . .
Timothy
Toys:
ForingaMex
Post by ForingaMex »
Good job, looks nice.
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
Caseys71
Post by Caseys71 »
8), The new seat looks great!
Casey
kelton
Post by kelton »
Quick question. My seats are in very bad need of seat covers, would you mind sharing where you got these lovely seat covers thank you.
Kelton
P.S. you seats look wonderful even godly :pray: :thup:
Old Bird wrote:I got a new seat cover from Mac's
++ Grits ++
Post by ++ Grits ++ »
nicely done......
Could you tell me the color combo on that seat? thnx.
"Hope and Change" = "Dope and Strange".......
We need a George S. Patton for president!
terry1167
Post by terry1167 »
I've been looking at the seat covers from Mac's and it appears that the seat covers are the bone oxen vinyl with the Sahara cloth inserts....looks very sharp. If you go to www.macsautoparts.com you can see the seat color samples.
'72 F250,390,C6,76K Sport Custom, Camper Special "Ole Blu"
'90 F250,460,48K XLT Lariat, Supercab
'88 Lincoln Mark VII LSC, 5.0 H.O.original, was daily driver, now retired
'97 Lincoln Town Car-Cartier,73K, 4.6, fact. dual exhaust,mint/original-Last Big Towncar
'05 GMC Denali XL,6.0 Vortec-for the wife & kids
'02 Cadillac DHS,4.6 Northstar-daily driver
'73 Great Divide 22' travel trailer,restored to original
'79 Mitchell 11' "Challenger XL" cabover camper-restored to original
'88 Lance 11'3" LC 780 cabover-current project
