And for my 3rd post... #$&* pig wont start!
So it was running and driving fine. About a week later it felt like it was running on 7. The points look fine (it's been 20 years since I messed with points, and im lucky to remember that much), I changet the plugs (fouled), and the cap and roter. No spark. I think the coil might be toast. It looks like it should have a B.C. in the part #. I started running #'s off stuff while I was at it.
C4AE-6090G heads
C4SE9425A intake
D4TE block (why not take the 64 block when your taking the other stuff?)
And I have not done the stroke to figure out the CID.
The truck is a 72 Highboy
Any idea about the lack of spark?
Erin
C4AE-6090G heads
C4SE9425A intake
Erin
Re: And for my 3rd post... #$&* pig wont start!
condesor ground
coil bad
brown wire from the starter realy not giving voltage
resistance wire burnt up
bad igintion switch
dead battery or bad battery connections.
those are everything i can thing of for no fire.
coil bad
bad igintion switch
Well, I cont. checked the wires. Looked good. I know the batt. is charged (on a batt. tender). I pulled the cap off and pulled the points apart to have a look, and they were kind of fused. The thing fired right up. So off to ebay to get a pertronix 1281/coil.
Erin
Erin
- Dragon
Pertronix ouch after all the cuss words lately about Pertronix go with Accel for less money and more reliability.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away.![Smile :)](./images/smilies/icon_smile.gif)
My Gallery
Spark test
My Gallery
Spark test
Thanks! I will look in to the Accel!
- BobbyFord
What's bad about Pertronix? I've had the same Pertronix in my '63 390 for about 8 years, never had a problem.
well the options are duraspark accel petronix and msd. did i miss any? factors in doing that swap. cost and ease of installation.
- Dragon
There has been several people here on this site complaining about their new Pertronix ignitors.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
- BobbyFord
I wonder if Pertronix has slacked off on their quality controlDragon wrote:There has been several people here on this site complaining about their new Pertronix ignitors.
![Hmmm :hmm:](./images/smilies/icon_hm.gif)
the last thread i read. it was the petronix2 that was giving troubles i think.
- Dragon
The 3 model got horrible reviews on the web somewhere. One of the car mag websites. I was just cruising one night and came across the article on the ignitor3.
But here is was the II that got hammered.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
O.K. Thanks for all the help. I went with the accel 2020, Accel coil 8040, and a new set of spiral plug wires. Pretty easy to install (I didnt pull the dist.), put it all together, and just cranked. Pulled a plug to look for spark and nothing. Started the BBQ and thinking "how would that be getting any voltage?". Went back to it and the directions didnt say anything about using the old coil positive, but the diagram showed it. So I half a*#ed hooked it up and BAM, fired right up. Running better than ever. Then I saw that I still had the test plug wire unhooked (I had put the plug in though, so stuff didnt get in). Turned it off, pluged in the 8th wire, and man what a differance! Still a little hesitation, but I think that is the Carter needing some dialing in.
So Thanks again!
Erin
So Thanks again!
Erin
