question about dimmer switch
LANCE65
Post by LANCE65 »
Can the stock dimmer switch handle full alternator voltage?(14.8 volts?) Thanks
-Lance
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..lol :D
Dragon
Re: question about dimmer switch
Post by Dragon »
It does every day of it's life.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away. :)
My Gallery
Spark test
LANCE65
Post by LANCE65 »
Cool, THANKS.
My reason is I am going to build a headlight harness with relays BEFORE the dimmer and that way only ONE relays needs to be used. Think this will work?
bluef250
Post by bluef250 »
The relay handles the power needs of the lights. The power circuit is connected directly to the battery and should have a circuit breaker (auto reset if you have one.)
The stock circuits (wires and both headlight and dimmer switches) then become a control circuit handling only a small part of the power.
ForingaMex
Post by ForingaMex »
LANCE65 wrote:Cool, THANKS.
In my opoinion that would defeat the purpose, to an extent anyway. You would be bypassing the headlight switch but the current would still have a long way to travel through the old thin/restrictive wire. I understand that your trying to get away with one relay instead of two but you would only reap about 1/2 of the potential benifit of using relays. That is just my :2cents: Others will come along and will be able to explain the pros & cons a lot better than I can.
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
LANCE65
Post by LANCE65 »
to bring this up again, I am actually working on my '77. I am not a big fan of the way split the headlight harness into 2 sides. I was wanting to kill two birds with one stone. Do you think the stock 16g wire will handle the power from the relays to the headlights? Thanks
Thunderfoot
Post by Thunderfoot »
16g is not heavy enough wire for the headlights... The stock wiring isn't up to much... Most of the new headlights use more current then the old ones and if you upgrade to higher watt lights it really wont handle it. You will see a big difference in brightness upping the wire size along with getting the full voltage to them. :2cents:
papabug71
Post by papabug71 »
I would use no less than 12ga. if it were me. Actually, I have a brand new 500ft. spool of 10ga. i've been itching to bust open, so i'de go with that.
10ga. might be overkill, but you'll never have to worry about it burning out :2cents:
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
