I know I have to put a wire in the hold and turn it one way or another bokk is no help
Dean
how to replace the key part of igniton switch
- Thunderfoot
Re: how to replace the key part of igniton switch
Start by removing the ground cable from the battery so there is no power to the truck, then stick your key in and turn it counterclockwise to “accessories.” While the key is turned to accessories, use a paper clip, or small piece of wire into the small hole in the face plate by your key. Press firmly with the wire while turning your key even further counterclockwise. Your key should rotate until it’s nearly horizontal, at which point you pull the whole key housing out.
Be sure the new key cylinder is rotated all the way counterclockwise before installing it back in the housing, then install and rotate back to ACC and remove the wire.
Thanks I got it before you posted and your right I forgot how done so many at least I can turn the key
Dean Gray
Dean Gray
