yep
thats right
right side has no power... . have some 69 shopmanuals...but not the one with the wiring diagram in
any ideas or connections...black tape over all cables..foot switch works..well at least left side has power
regards stig
half beam not working 69 f100
Re: half beam not working 69 f100
so you have no low beam but you have high beam? is the bulb good? check the plug on the headlight and see if it is giving power to the low beam side of the connector. here is the 69 diagram. http://www.fordification.com/tech/wirin ... _81-85.jpg it shows everything going to the other light and then to the dimmer and from the dimmer to the switch. so it has to be from where it hooks up with the other side to the bad light.
hehe
just found it
years ago...hopefully
somebody has been doing a rustrepair to the battery tray
think some cables got involved
one cable was thin and green..guess what cable
now I have both half and full beam..on both sides
time for swedish inspection
regards stig
just found it
regards stig
