I know that it should be closer to 6vdc for the coil at the resistor wire, but why would they run the wires that way? Given the rule of path of least resistance, this set up will never work right.
Does anyone have a suggestion.
fordman wrote:now the coil recieves power from two different wires when the truck first tries to start. one is from the pink number 16 wire from the iginition switch the other is a brown wire that comes off of the starter realy a full 12 volts to help start the truck. only hot when the switch is turned. then when the switch is let off of the wire doesnt send power to the coil to start anymore. the pink wire takes over and sends the resisted power to the coil for run.
