ONE BRAKE LIGHT Working
I have looked over a few threads but cant find anything that is helping. The passager side brake is working but the drivers side is not. It worked before! All lights are working fine when I turn them on. Its like I get everything fixed and I just keep fixing stuff
Re: ONE BRAKE LIGHT Working
probably a bad bulb or socket. wiggle the bulb. or replace it. or you can buy new socket guts at the parts store. it will be for trailer lights but the principle is the same. it has two connectors on it with two wires. or maybe the wirign connections and dirty or loose under the truck.
Ill check it again, thanks fordman!
I just notice when I turn my turn signal on it works fine. And now the brake light works, but it go's on and then doesnt work when I apply brakes. Weird
- BRUTUS_T_HOG
i agree on checking the socket. get behind the socket and wiggle and push in on the wire. or use a test light to check for power to the appropriate wire.
also the most common cause i've found to be is faulty trailer wiring.. so if you have a trailer harness installed, get under there and wiggle the connections
ASE Certified Technician
I brought a new bulb going to try that first, and clean wire
- Thunderfoot
That is a common problem that is related to the Turn Signal Switch (TSS). Try wiggling the Turn Signal Lever and see if it makes the light go on and off, if so the contacts in the switch are going out and you need to replace it.
If the light works with the turn signal then there is not a problem with the bulb or socket.
I actually went and brought a new bulb and it seems to be working. The old bulb was pretty dirty! thanks guys again
Well as usually! Im going to try a new socket now because its still doing it. Ill keep you posted
- mlheppl
Thunderfoot wrote:That is a common problem that is related to the Turn Signal Switch (TSS).
If the bulb flashes with the turn signal, then the socket is OK.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
71 F250 4X4
mmm its got to be a wiring issue
not exactly the contact in the socket on one side can be worn down when the other isn't.
mmm ok Ill check, I bought a new socket just havent installed it
- Hawkrod
If it works with the turn but not the brake it can't be the socket because they use the same post in the socket. There are two posts and one is for brake AND turn and the other is for the running lamp. The bulb grounds through the base. If it always works for turn but not brake then it has to be a bad turn signal switch connection as that is the only point at which the wiring seperates. The brake light power comes from a single wire to the turn signal switch where it is split to two sides and you say one always works so we know you have power at that point. If the turn signal always works then we know that the wire from the switch to the tail light is good as well so that means it is bad contact in the switch which is very common. There are contacts in the switch that are basically rivets that the wires are attached to. When they overheat they melt into the plastic of the switch until they no longer contact the wiper. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- SteveC
turn signal switch is where im placing my bet as well.
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
