CrownVic fan wiring
Brokenarrow
CrownVic fan wiring
Post by Brokenarrow »
I lucked onto a new electric fan that was ordered for a crown vic police car and never used. I'm thinking seriously about installing it in my '68 but I'm not sure about the wiring. :hmm: The plug has 3 wires, black red & blue. It also has what I assume is a thermostat that is attached to the shroud and wired into the fan motor. I know I'll have to use a relay (50 amp maybe?) Any advice or actual experience wiring/using one of these fans will be appreciated.
'68 SWB f100, 401ci FE/C6, '68 Mustang fastback (restoration in progress)
2013 F150 KingRanch (ecoboost), '48 8N tractor
"Be more concerned with your character than your reputation, because your character is what you really are, while your reputation is merely what others think you are."
— John Wooden
basketcase0302
Re: CrownVic fan wiring
Post by basketcase0302 »
I'm gonna take a guess here, (that it's similar to the electric I had on my old style Bronco).
Black should be your ground.
The Red should be the high speed hot wire.
The blue should be the low speed hot wire.
You should be able to bump the wires to a power source for a second to confirm this, (without any damage to the fan). Or if you have an ohm meter you could check the resistance between black and red/then check the resistance between black and blue.
If your ohm reading is a higher resistance on the black to red / than the ohm reading on the black to blue / that will confirm high speed. :thup:
