interoir door handle ratels
harveyracing06
Post by harveyracing06 »
the interoir door handle ratels is this just from old and worn handle should i buy a new handle or is there a way to fix this?
Re: interoir door handle ratels
it could be from worn handles. here are some good handles so you can see if yours are worn or not. the tabs should be smooth like these.
harveyracing06
it has play when mounted then when u drive it ratels.? you can move the handel 1/4 inch when mounted before it comes in contact with the inner door lever
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Well, it's either worn or loose....and there's only one way to find out. ;)
they do sound like they ar worn. take them off and look at them. they may be sharpened almost to a point or have a groove in them. if they are then replacing them is the only way to fix the rattle.
harveyracing06
thanks everyone!
