Ballast resistor
Ballast resistor
Would a 1970 f250 with a 360 use a ballast resistor?
Re: Ballast resistor
not originally. it would use a resistor wire. pink from the ignition switch to the firewall and then it would be a different color out to the engine.
if i were going to rewire it could i use a ballast resistor in place of that pink wire
- Hawkrod
Just curious, why? It is not like they fail very often. There are literally millions of Fords on the road that use the wire and it isn't an issue so why fix something that is not broken? The way I see it, it is kind of like saying "if I were going to put in a new engine, I would use a Chevy". Hawkrodbiggreg70 wrote:if i were going to rewire it could i use a ballast resistor in place of that pink wire
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
im rewiring the whole truck with a painless and they give you one with the harness.
- mk
I think very few people would do that for the heck of it. A friend bought a '67 Fairlane rewired by some amateur that didn't understand the Ford wiring and it's got a mopar resistor that seems to be working so far...
mike
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
~Will Rogers
- Thunderfoot
Yes, if you are rewiring the truck you need to use a ballast resistor or a resistor wire for the coil, unless you are upgrading the ignition system to one that uses full 12V to the coil then you don't need it. FYI the you can get a new resistor wire at the parts stores if you don't want to use the ballast resistor, but both do the same thing...biggreg70 wrote:im rewiring the whole truck with a painless and they give you one with the harness.
Thanks Thunderfoot
