1967 ford f-100
ks sailor
1967 ford f-100
Post by ks sailor »
Having all kinds of problems. No spark from ignition coil, headlights won't work, and battery keeps running down and won't jump start. Other than the obvious, I have a ground problem, any ideas?
Re: 1967 ford f-100
bad key switch maybe. power for the coil comes from the key. and only at start up direct 12 volt boost comes from the solenoid. try wiggling the key as you start it. see if that helps.
TX69F100
Re: 1967 ford f-100
Post by TX69F100 »
Also, check your ground(s).
Brent
1969 F100 Ranger 390/C6 <--- Build thread
fordamericana
Re: 1967 ford f-100
Post by fordamericana »
ks sailor wrote:Having all kinds of problems. No spark from ignition coil, headlights won't work, and battery keeps running down and won't jump start. Other than the obvious, I have a ground problem, any ideas?
That sounds like a project, like mine was, I spent a couple weeks just going through the wire harness one wire at a time, and repairing the rats nest of cuts and splices under the dash and behind the cluster...
This should help...
and there is more here...
http://www.fordification.com/tech/schematics_h.htm
I likes My FE I does...
