glove box emergency flasher
- kilog55
anyone make a repop of these? or know where i can find one my internals are missing everything else is there though
Re: glove box emergency flasher
do you mean the switch itself if so there is a nice one on ebay now
69 ford f100 Longbed restored 360,auto
71 ford f100 302 3spd shortbed my daily driver
only one place has a repop of these. and they are way out of line as for price. search ebay or ask in the parts wanted to get a good used one. these are the same for most fords including mustangs trucks fairlanes galaxies and maybe more.
- Fordman5
I found my switch when I was taking the dash apart for a new windshield. Not sure where the wire are to hook it up?
Proud owner of a 1967 Ford F100
The wiring is probably hanging behind the glovebox insert.
- Fordman5
I did see the wires for the missing radio ![Smile :)](./images/smilies/icon_smile.gif)
- pfijma
Hello,
I have only the face plate laying around in my parts box!
See picture...
Paul
See picture...
Paul
Paul
'71 F250 Sport Custom Camper Special
- kilog55
yeah my plate is good, found another switch in the tool box under the hood that one doesnt work either and i have no power over to the switch ill clean the terminals better and see if it was just gunky.
- la1031
Does anyone have a picture of how the glove box emergency switch looks installed. I cant remember how to put mine back together, soooo many parts......... ![Confused :?](./images/smilies/icon_confused.gif)
http://s446.beta.photobucket.com/user/1968F100/library/
1968 F100 Shortbed
302/306 roller, C6 w/shift kit
3.70POSI w/trackbars
Hydro-Boost
Hoping for 13's and looking good doing it !!
Makita Industrial Power Tools
Tools for the long run.
1968 F100 Shortbed
Hydro-Boost
- kilog55
think its upper right hand corner attatched to the cardboard liner itself
yes ontop of the glovebox is the backup plate then the hazard swithc goes inside the glove box the screws go up from the bottom and through the plate to hold it in.
My 67 it is in the top left corner of the glove box, the one I got the switch from at the salvage yard had it in the top left as well as all the ones that the switch was removed from but the plate's were still there. I can't remember seeing one in the top right side but I can't say for sure. I think I do remember seeing the one in my 350 down under the dash but not sure if someone moved it there or not.
- kilog55
i was just guesing on location cause the wires are kinda short to run closer to the radio
- Mancar1
If my adled brain remembers, I will take and post a pic of mine latter today.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- Mancar1
Here is the one in my 68. Hey I remembered ![Happy Dance :hd:](./images/smilies/icon_dancing.gif)
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
