Dual Brake Idiot Light
Racer Z
Post by Racer Z »
On my 69/70 F250 there is an indicator light in the dash just above the parking brake. It seems to be part of the brake system, probably an idiot light telling me that the brakes have failed. I can't figure how to remove it with out breaking it. I want to move it over to my other truck that I am fixing.
Does anybody know how this is done?
Thanks.
Re: Dual Brake Idiot Light
reach under the dash and hol dthe socket out towards the dash. then push in and turn the bezel and it will come apart.there is a spring in there holdign tension. that is why you may want to push out on the socket on the back side.
Racer Z
Post by Racer Z »
Yeah I found the spring the other day. I will try pushing in and turning the bezel as you say.
Thanks.
70_F100
Post by 70_F100 »
fordman wrote:reach under the dash and hol dthe socket out towards the dash. then push in and turn the bezel and it will come apart.there is a spring in there holdign tension. that is why you may want to push out on the socket on the back side.
Fordman is 100% correct.
It's similar to changing a taillight bulb. Push in and turn. :thup:
whats the difference between a light bulb and a pregnant lady?
you can unscrew a light bulb.
Racer Z
Post by Racer Z »
lmao
TONYMAC35
Post by TONYMAC35 »
REACH UNDER DASH AND PUSH IN AND TURN TO RELEASE,WHILE HOLDING OUTSIDE OF DASH LIGHT BEZAL.
Racer Z
Post by Racer Z »
Caps is considered to be YELLING in an electronic forum.
I have not been able to force it to turn. It does push in however. I suppose I should spray it with WD40 and let it soak a while.
1972hiboy
Post by 1972hiboy »
fordman wrote:whats the difference between a light bulb and a pregnant lady?
Hahah Ill have to remeber that one........
Rich
Dont eat yellow snow.....
i got that from a movie i had watched back in the 70's.
Racer Z
Post by Racer Z »
My light must be pregnant.
