column bearing
- jimmy828
column bearing
i am replacing the bearings and other parts on my steering column.When i disassembled the column i noticed that the lower column bearing fell out and hit the floor.What i like to know does this lower bearing get pressed in.Thanks
Re: column bearing
no it doesnt get pressed in. it is held in place by one of two methods depending on the year of the column. the 67-69 column shaft has a clamp that slides up to hold the bearign and shaft adjustment in place. the 70-72 has a collar that does the same thing. it holds the bearing in place when the column is adjusted to the right place.
- jimmy828
Re: column bearing
thanks fordman! Thats was what i hoped it would be.I will also be contacting you on more parts to buy soon.
Re: column bearing
what does the clamp look like
67 ford f100 custom /390 4spd
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
Re: column bearing
you can see it above the shift arms on this old picutre. it is just asteel band the botls together where it meets up.
