original bolts
original bolts
does anyone know or remember what the two inside bolts that hold the factory a/c box up to the dash look like? are they a body looking bolt or are they a bolt that loks like the kick panel vent bolts?
- 70_F100
Re: original bolts
5/16-18, has the head with a ring around it and a washer attached.
Not the same as a fender bolt, if that helps.
I'm not at home, so I can't get a pic for you.
That's not an oil leak
Re: original bolts
ok thats what i thought. after i thought about it for a little bit. only thing is this is what i have. i have 3 of the ones on the left. and 6 of the ones on the right. two of the ones on the left probably go to through the firewall into the a/c box. 4 out of the 6 go to the kick panel vent seal. so i am left with one of the left ones. and two of the right ones. and no dash bolts to hold the a/c up. but this bow has been out before i can tell it was all taken apart and not all the screws were put back in it either.
