Project: One Refined 69
Hey Guys wanted to turn this into an official build thread. I bought this truck when I was 14 and in jr high, now 12 years finally ready to make a push to get it finished. I am in no hurry to get it done just want it to be perfect, thats were the name comes from i will finish this project. Here is were it stands now!
Frame is smoothed and ready for 4-link
Last edited by bossperformance on Wed Oct 03, 2012 2:58 pm, edited 2 times in total.
- 390Nut
Re: Pics of my 69 build finally!!!!
Cool looking shock setup, never seen that before. Got any info/links?
Paul
`69 F100 390 4spd driver
This is something I dreamed up. I cut the top of the spring perch out and welded the cups on the top. The bottom is a mount that I made it is held on by the I beam bolt but will also be welded to the radius arm when finished. This setup should get my truck pretty low, the cross member is just high enough to get your foot under it!! I already had the drop beams and wanted to go lower so this was what I came up with. The shockwaves are from AIM and are custom built to my specs.
Here are some pics of the cab. These pics are a bit old it is in primer now and about to go off for some body work.
Cleaned up around the hinges
Steering column cleaned up
The floors patched, gas tank filler filled, and hey a peek at the f600 gages
Steering column cover made from two of the stock ones and a piece of pipe
Here is what the dash looks like with stainless trim from a ranger and a custom heater control/ cd player mount fabed into dash
Here are some pics of the kick panels. They are the ones from Rod Doors. The speakers are 4inch Rockford Fosgates mounted in custom rings made from MDF. I stayed old school with factory heater and side vents. No A/C on this baby.
Here are some pics of the motor. It is a 408 with a 4340 steel crank, Carillo rods, SRP pistons, Custom grind Comp Cams hyd. roller retrofit cam, AFR cnc ported heads, Victor Jr. intake, MSD billet distributor, and a Race Demon 850 carb. All cast was removed from block and it was painted with Dupont Black with House of Kolor clear. I spent about 15 hours removing cast from the block, it looked like chrome...it was almost a shame to paint it.
Here are some pics of the doors. I just finished making the door skin look better. I filled in gaps so the skin is uniform all the way around the door. Sorry these pics kinda suck but you guys get the idea....
- survivorman
Can you post some pics of your hair pins?
Sitzungstiefpunkt und fahrend langsam
- 1972hiboy
I love the fact that you have your motor on a cradle in what looks to be the [censored]. I like how you roll.
Rich
Dont eat yellow snow.....
- fireguywtc
Excellent work!
Bill
That engine is a work of art!
69 F-100 project
Hey guys,
My situation has changed so I have not gotten much done in a long time. The Cab is at the bodyshop but I have moved about 4 hours away from the shop where the rest of the truck and my tools are so I have not gotten much done. I did get the 4 link in the back and started mocking up the drivetrain as well as the gas tank. I will be using a 67 mustang tank between the framerails behind the rearend. Here are some pics of the frame and 4 link.
- FoPAR
wow 4 hours away...that sucks very hard to work on a project with that kinda drive. Looks good so far
"FoPar" because I love Fords and Mopars so just call me FoPar...
Sweet looking ride. Are the 4 link brackets custom or off the shelf? I like that Shelby in the background, good taste. Post some pics of it.
- grabberblue72
lookn good!!
