Improper gear selector read
- mark F-100
Hi folks! Just wondering what you did to make the gear selector read proper on steering column. Changed motor and trans. What I got now, is park is park low gear reads N on selector.I've got a project thread up in that section of my truck build.
- mark F-100
Re: Improper gear selector read
Sorry I'll try to be a little more specific, trany came out of 71 Merc. Trany is a C-6, it seems to have a shorter stroke between gears than original trany. Doesn't matter how i adjust the rod, still reads improper on selector.
The shift lever on the side of the transmission is too short for your truck's shifter. In order to get it to read right, you really need to get the longer shift lever from a truck transmission. You'll have to drop the transmission pan and remove a nut to get that thing out of there. It's a bit of a pain, but not impossible.
- mark F-100
Thanks I have a longer shift level from the orig. tran. from the truck. To bad I didn't put on when the tranny was rebuilt. You always forget somthing
- Brokenarrow
I did the same thing when I built the C6 for my truck
Had to drop the pan and pull the valve-body to change it out
'68 SWB f100, 401ci FE/C6, '68 Mustang fastback (restoration in progress)
2013 F150 KingRanch (ecoboost), '48 8N tractor
"Be more concerned with your character than your reputation, because your character is what you really are, while your reputation is merely what others think you are."
— John Wooden
— John Wooden
Or if you are not a perfectionist just cut off the lever from the old transmission and weld it to the new transmission at the right length.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- Brokenarrow
I thought about doing that but I was afraid I'd melt the shift selector seal, and/or the kick-down lever O-ring.cdeal28078 wrote:Or if you are not a perfectionist just cut off the lever from the old transmission and weld it to the new transmission at the right length.
clint
— John Wooden
— John Wooden
