So im thinking of putting a 67 rear view mirror on my 72?? I know the 67 attaches to the cab vrs the 72 on the windshield (will it attach to the 72?).. Then I suppose the question is will the sun visors work or can those be changed to a 67?? Thoughts??
Todd
67 rearview mirror on a 72?
- zakt
1972 Ford F350 crewcab
- Doug F
Re: 67 rearview mirror on a 72?
It should work. You will need to buy the bracket first and then trace the holes and use a SHARP nail or something to punch the holes. I am almost positive that the visor brackets are the same, but they have a rod that slips in the other end that might make it different.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
http://www.pinheadlounge.com/Pinecone
https://www.facebook.com/PineconeDesign
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
i think you can use the 72 visors with the 67mirror bracket. you may only need to make one new hole to mount the bracket. but i am guessing.
- Doug F
http://www.fordification.com/tech/67-72ID_01.htm
From Kieth's pics, it sure looks like they will work.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
i should have looked before. you will have to drill all new holes.
