Redoing some Door Panels
- billbates40
I took off my door panel to remount my speakers. Here is what it looked like.
- billbates40
Re: Redoing some Door Panels
I'll post the final results once I get my speakers and everything mounted. Hopefully she don't rattle.
how did you get the vinyl to form so tightly around those letters?
- billbates40
You have to stretch the vinyl, I really needed to even stretch mine more. The store I went to had 4-5 different grades of vinyl, just make sure you get the kind that can stretch. I used foam from a craft store, you can get the pages for about a buck and a half, to cut out the letters. A good tip is the bigger (not thicker) the letters the easier it is.fordman wrote:how did you get the vinyl to form so tightly around those letters?
so the flames and letters are made of foam? so i could make any design i wanted under a panel like that.
- Caseys71
Casey
- billbates40
Yeah. I just found a font I liked that wasn't too fancy. The ford emblem would be tough cause of the writing. The foam I got at Joann Fabrics. It is called Foamies and is 3mm thick.fordman wrote:so the flames and letters are made of foam? so i could make any design i wanted under a panel like that.
I went down to a stereo installation place and asked for some tips. The installers do this all the time with speaker boxes and they were very helpful.
I used DAP contact cement to attach the vinyl to the wood.
- billbates40
Now to see about doing the headliner.
now thats an idea and a half.billbates40 wrote:Now to see about doing the headliner.
- zoomer
What did you do about the mounting clips? I've been looking at doing this same thing.
1971 Ford F100 Sport
302 3 on the tree
Revelation 12:11
And they overcame him by the blood of the Lamb, and by the word of their testimony; and they loved not their lives unto the death.
By this I am a Monster to the Monster!!
- billbates40
That is the question. Right now I don't have any clips on it. I do have holes in the wood that match up with holes in the door and I was going to use dry wall anchors in the door holes then screws through the wood. I put foam weather stripping behind the wood in places to make sure I didn't get rattles and once I hung it to check fit I found it is on pretty tight with out putting the screws in (fingers crossed). I'll run it like that for a little bit to see if I can get away with out using any clips.zoomer wrote:What did you do about the mounting clips? I've been looking at doing this same thing.
- Joshpow
u want to do me a headliner?? i want flames or a big ford oval with ford script lettering!!
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- billbates40
Nice! I'll do mine and see what is involved, maybe I can make some extra.Joshpow wrote:u want to do me a headliner?? i want flames or a big ford oval with ford script lettering!!
- Joshpow
man i really like those panels. they are definately gonna look much better than the old ones.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
that's trick! how hard was it to get the vinyl to stretch around the script and flames?
