Door stuck closed from inside only
hey all, quick Q for you guys. my door on the truck is only hard to open from the inside, opens an closes super nice an easy from the outside but as soon as i need to get out of the thing i have to shoulder ram the *******
any ideas
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
Re: Door stuck closed from inside only
the tit on the handle may be worn down and not fully opening the latch.
The tit? whats that?
-Mike-
ECV 1849
ECV 1849
- forrestbump
Inside the interior door paddle latch is a 3/4" (approx.) tip that presses against the inner door latch mechanism and it opens the door. If/when that point breaks off, you'll not be able to open the door easily or at all.
Larry
Larry
tit nub the thing sticking out from the handle. the stub that sticks above the metal piece in this picture. can get worn down. metal or plastic handles will do it. the rod inside the door can could bend. the latch itself can crack and still be there to barely operate the rod to open the latch.
Thanks for the help an the pics guys ill check it out in the morning.
-Mike-
ECV 1849
ECV 1849
