How do you remove the turn sig. lever
f100ranger1969
Post by f100ranger1969 »
I finally got a chrome turn lever for my '69 and wanted to swap out the old black one but I can't seem to get the old one off. I was under the assumption that it just unscrewed. This is how I got one from the junkyard off a '66. Now I've chewed up my original with a pair of pliers tring to force it but it will not move. Any suggestions?
'69 Calif Ranger in PA, 2001 GMC Sierra SL 4x4
Liar, Lawyer, Mirror show me, Whats the difference?
71-F-250SC-72-F-250C
re: How do you remove the turn sig. lever
Post by 71-F-250SC-72-F-250C »
I thought it just unscrewed, all of our trucks do. I even play with that thing when I am bored when I am waiting in the truck for some reason.
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic. :)
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
jzjames
Post by jzjames »
:lol: me too. I keep thinking I will put some lock-tite on it so I wont keep unscrewing it while Im sitting at a light or something.
1970F250
Post by 1970F250 »
mine is rusted on. try wd-40
Steve
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
flyboy2610
Post by flyboy2610 »
It should just unscrew. I would pull the steering wheel and take a look in there to see if something is binding it up.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Yes, it just screws into the turn signal switch. Be careful messing with it though...or you might end up breaking that switch. :o Here's a visual...the yellow arrow points to where the turn signal lever screws into the switch:
f100ranger1969
Thanks for all the info guys. I guess mine is just corroded in there. I'll keep working it. WD-40 wont cause any problems in there with the switch will it?
It shouldent, I think the worst it could do would be clean out the electrical stuff, and maybe help reduce corrosion.
72 f-250 Custom
03 mach1 mustang
FORDification
Site & Forum Admin
Site & Forum Admin
Try a quick squirt of PB Blaster instead of WD-40. It works better as a rust penetrant.
f100ranger1969
Will try it, PB Blaster is my usual choice anyway!
crazyace99million
Re: re: How do you remove the turn sig. lever
Post by crazyace99million »
f100ranger1969 wrote:Will try it, PB Blaster is my usual choice anyway!
yeah, way to suck up. i always used wd40 lol.
flyboy2610
WD40 is not actually formulated as penetrating oil. It's a little to thick to work efficiently.
It actually formuled to displace water. (Water Displacer40)
Velcro
Post by Velcro »
My first '68 Ford 4WD, picked up in 1999, needed some interior work where I had to pull the bench seat. Then I decided to install new carpeting, which meant I had to remove the seat belt brackets.
Since this truck had spent all those years in the snow and salt of Wisconsin's Northwoods, I figured I'd never get the bolts out. I used a quick squirt of something my buddy gave me on each bolt end, under the cab, had a smoke, and they walked right out. The product was JB-80, and is advertised as "Twice as Good"! It's similar to WD-40, but nails rust also. Moving to Tennessee, I couldn't find it around here, so "Knock-R-Loose" and Liquid Wrench fill in for me now.
Too many guys rely on WD-40 for everything, and it wasn't made for everything. It's basically a lubricant.
Bill
460 crew
Post by 460 crew »
I just use WD40 for giving stuff ***BLING*** and attracting dirt. :lol: :lol: JK I'm a firm believer in the PB Blaster also. Good stuff but hate the smell but for some reason it's addicting.
cdeal28078
Post by cdeal28078 »
71-F-250SC-72-F-250C wrote:I thought it just unscrewed, all of our trucks do. I even play with that thing when I am bored when I am waiting in the truck for some reason.
I also do this. I wonder how many times my turn signal lever has been unscrewed and screwed back in? Been driving my truck 25 some odd years. lol
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
