heater core
heater core
i did not know where to put this thread but i removed the heater/motor underneath the dash. i see the system has a few bolts and i see their are rivets.do i remove the rivets to install the new heater core and rivet the box once again?
- flyboy2610
Re: heater core
To replace the core the box has to be removed from the vehicle. There are a few nuts accessible from the engine compartment that holds the box in. Remove the box, then you can remove the bolts from the box to get the core out. You do not need to drill out any rivets. Make sure you mark which cable goes where before you start.
- basketcase0302
Re: heater core
I've slept since then ha-ha, but it seemed like I did have to drill two rivets to get here:
- basketcase0302
Re: heater core
Here's a better picture showing the rivets that have to be drilled:
- 70_F100
Re: heater core
Here's an EXCELLENT tutorial from Robroy: http://www.fordification.com/forum/view ... er+rebuild
That's not an oil leak
