Got started on bodywork today [LG. PICS]
Well, I stopped by the local parts outlet a couple days ago and picked up the body filler, since I knew that this weekend I was finally going to be ready to start using it. I got the good stuff: Evercoat's Z-Grip filler and glaze coat:
Since I've decided to go ahead and use the factory A/C setup, and therefore needed to use the '68-up heater control setup, I had to get the dash of the '67 cut out to accept the patch panel I cut last week. I went ahead and mocked it up to make sure it would fit flush and would look OK. Here's what that looks like:
There are three small sheetmetal screws holding the top of the panel, but these will be hidden under the edge of the dashpad. On the bottom it's held in by the regular dash support brace and another screw, both of which will also be hidden by the installation of the underdash unit. Once this panel is cleaned up and painted the same color as the rest of the dash, it'll be almost invisible.
I then got started cutting the top firewall hole for the A/C lines. Didn't have the right size hole saw so I just drilled a large hole and then widened it out with the diegrinder, and drilled two holes for the gasket retainer, so now that part's ready for the new A/C hoses. I then popped some body plugs into the standard heater hose holes (since they're no longer needed), and drilled new holes down lower on the firewall, which is where they're needed for the factory A/C setup. There was already two dimples where the holes needed to be drilled, so it was a no-brainer. I installed two body plugs into these holes and then drilled through them just enough to that the hoses would be a tight fit.
I then got started sanding down the areas on the cab that needed a little body filler. There were three small dings in the cab roof, two along the driver's door pillar and one on the back of the cab....in addition to the touch-up that needed done around the rear window to smooth out the holes I welded up last weekend, as well as finishing up the fuel tank filler hole. Once the metal was cleaned and prepped, I mixed up the filler and applied it as needed. The first batch I mixed up I found I used a little too much activator, as it was drying on my pallette within minutes, so I just threw it away and started over. The next time around was better.
While it was drying I cleaned all the black goopy windshield sealer out from around the windshield area. I found that the POR-15 MarineClean works really well for this. Here's a shot of the cleaned-up windshield area taken while the filler around the back window was drying:
There's a few more pictures taken, I'll get those posted to a new project update page within the next day or two. When I get back to the shop next weekend, I'll be spending the day sanding the cab, since I'm basically ready to start painting it. I'll be also doing any bodywork needed on the rest of the frontend sheetmetal (doors/fenders/hood), since I want to have them all ready so that they can be sprayed at the same time. I'll probably spend the next week doing final research into paint products....
...but just to let you all know, I believe I've decided to go with black. I might add some accents later, either blue or silver, but black will probably be the main color coat. I think although it'll require a little extra time making sure that everything's nice and smooth, it'll be worth it in the long run.
- 72hiboy4x4
- dablack00
re: Got started on bodywork today [LG. PICS]
Keith,
The truck is looking great. When I'm finished getting my 71 XLT on the road, I was going to start on my 68 ranger SWB. I was planning on painting it black and put in factory AC. Everything you are doing is really helping me out. Take as many pictures as you can of the holes you drilled and everything you do to put the factory AC in the cab. I know alot of guys are very interested in doing this but don't know where to start.
thanks again,
Austin
thanks again,
Austin
- SmokeyBear
I'm going to be attempting to paint this myself, using an older Binks Model 7 gun, which was the professional's choice prior to the current crop of HVLP guns. It was given to me years ago by a buddy at a local body shop when they upgraded all their equipment, and I've used it once, to paint the frame of my 442. But I'm going to have to do a practice run or two to get the settings and procedure down before attempting it on my truck.
- flyboy2610
That is really looking nice, Keith!
Not that I am trying to talk you out of it Keith but black sounds and looks really cool but it is a B#$%h to keep it looking good and what I understand a real b#$%h to prep to make it look good when you paint it, especially your first try at painting. Again if black is what you want DON'T listen to me at all, just something to think about.
Fuzzier
Fuzzier
Yeah, I know all about black vehicles. About half of the ones I've owned in the past had a black interior, and I once owned a '74 F100 that was painted black...and my '68 Galaxie that was midnite blue (almost black). It was definitely more work to keep clean, but man they were sure purty in the sunlight all waxed up.
I don't know, guys. I guess I just decided on black to make it more of a challenge and to force myself to spend a little extra time getting the body straight. However, I have to admit that I still haven't completely decided, though I'm going to have to very soon. I'll give it some more thought. I appreciate all input, pro and con.
- SmokeyBear
- Mohillbilly
100% Kieth is Mr. Patience and detail seems to be an obsession. Go for it!
70 Custom LWB, 302-2V, 3 on tree
Keith
Even with what I said black would be beautiful. I had a black 2000 Z28 that was awesome (but hard to keep clean ). If black is what you decide we will support you on your discission 100%
Fuzz
Fuzz
Well, I just got back from spending almost 5 hours stripping paint from the cab, and I'm a little more than half done. Another evening after work like tonight and I'll be finished with that part. It's getting taken down to bare metal. I'll have to post a few pics when it's completely stripped....starting to look pretty cool, all shiney and everything.
