1940 Ford steering wheel
Venado82
Post by Venado82 »
Does anyone know if a '40 Ford steering wheel will fit the standard column of a '69 Bump? It's a standard cab truck. I've got a guy who wants to give me one if it will fit. The wheel is in decent shape and complete.
Half of something is better than ALL of nothing!
http://www.facebook.com/anthony.inman#! ... 1184119868
Hawkrod
Re: 1940 Ford steering wheel
Post by Hawkrod »
Venado82 wrote:Does anyone know if a '40 Ford steering wheel will fit the standard column of a '69 Bump? It's a standard cab truck. I've got a guy who wants to give me one if it will fit. The wheel is in decent shape and complete.
Unfortunately it will not bolt on as the later ones were a splined straight shaft while the early ones are a tapered smooth shaft with a key. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Venado82
Post by Venado82 »
Thanks Hawkrod. I'll keep looking for something I like. Maybe I'll get the wheel and resto it just to have or turn a little profit.
elgemcdlf
Post by elgemcdlf »
You can do a couple things with the '40 steering wheel. You can cut the center out of your wheel and weld it into the '40 wheel. You could also have a machine shop fab an adapter.
Venado82
Post by Venado82 »
I hadn't thought of that. I might look into have a local shop fab an adapter.
