1967 F100 6-cylinder to 390 swap (transmission question)
fslay0435
Post by fslay0435 »
I got my first bumpside truck today. SWB 1967 F100 with a 240 6-cylinder and 3-speed on the column. I've posted in the engine section as well, but I got a transmission question. My truck is already set up for a manual transmission. It's a column-shifted 3 speed. My ultimate plan is to install a 390, and I'd like to keep a manual transmission in it. I would honestly be happy to find a 3-speed transmission that is compatible with a 390 and just keep the column shift mechanism. The truck isn't going to be a hot rod anyway. So I got two questions:
1. If I find a 390-compatible 3-speed and keep the column shift, what kinds of additional parts will I need to make it work? I'm asking about clutch levers, bell housings, clutch, all that kind of stuff.
2. Is it possible to make a 4-speed toploader from a car work with a floor shift? I'm asking this purely out of curiousity, and just wonder how hard that would be to make work.
Thanks in advance
1967 F-100 240/3-speed SWB bought from original owner. Soon swapped to 302 or 390
"TEACHERS: FIGHTING THE FORCES OF IGNORANCE"
AlleyCat
Re: 1967 F100 6-cylinder to 390 swap (transmission question)
Post by AlleyCat »
Welcome fslay0435. Your swap is pretty straight forward. I read your post in the engine section and wanted to see what you had in mind for a trans before answering. The 6 cylinder engine stands are the same as 390 stands but they have to be relocated on the crossmember. The bolt holes are already there. The trans you have will bolt up to the 390 bell housing allowing you to keep your column shift with no mods. You will definitely need a bigger rad to handle the 390. You'll also need the clutch bellcrank pivot that bolts to the block from an FE series ( 352,360,390 ) powered truck to make the cluch linkage work. Throttle linkage will be different also. I can't remember if 6 cylinder and V8 used different gas pedals but hopefully someone who knows will chime in. For the small stuff you might be able to find a donor truck in a salvage yard. Ford used the FE series engines all thru the bumpside ( 67-72 ) era and in dentsides from 73-76 so you should be able to find the stuff pretty easily.
:wel:
Clay
chrisg
Post by chrisg »
i need to know i have a 91 f150 straight six 4.9l with a five speed 4x4 tranny and want to put a 390 in it the 390 has a 4spd bulldog will i have to change out bellhousing or will it fit?
72BahamaBlue
Post by 72BahamaBlue »
You'll need a different accelerator pedal/assembly for the FE.
In the photo, left to right;
240-300, 302, FE
chrisg
Post by chrisg »
chrisg wrote:i need to know i have a 91 f150 straight six 4.9l with a five speed 4x4 tranny and want to put a 390 in it the 390 has a 4spd bulldog will i have to change out bellhousing or will it fit?
nevermind i need a whole new tranny the bellhousing dont unbolt on the one in the truck
68shortbed
Post by 68shortbed »
The 4 speed toploader is a bolt in swap on a shortbed.
72lwb
Post by 72lwb »
I have pretty much the same question but Im looking at buying a 72 lwb again but its a240,6cl with the 3 on the tree (bad clutch) I want a floor shift is the set up the same or were there any changes I need to worry about? P.s. The truck is 600 bucks needs tires and clutch to be drivable good deal?
AlleyCat
Post by AlleyCat »
72lwb wrote:I have pretty much the same question but Im looking at buying a 72 lwb again but its a240,6cl with the 3 on the tree (bad clutch) I want a floor shift is the set up the same or were there any changes I need to worry about? P.s. The truck is 600 bucks needs tires and clutch to be drivable good deal?
Set up is the same. Needs tires and a clutch for $600? Unless it's a total POS I'd say grab it. :)
Clay
tmcalavy
Post by tmcalavy »
Where are you guys ding these engine swaps? I need a good used 300 I6.
