Dash inserts
roughneck
Dash inserts
Post by roughneck »
Has anybody used the dash inserts that Carolina Classics makes? It looks pretty cool, and since my gauges are ready for retirement, I wondered if anybody had tried thesse and if its worth the $145? http://www.carolina-classics.com/Detail ... ategory=17 :fr:
Swegner99
Re: Dash inserts
Post by Swegner99 »
I have seen those before (NPD catalog if I remember right) and I think they look great, I plan on using one. I have not seen one in person though. I wish the speedometer hole was a little bigger but thats how it goes I guess. If you decide to get one be sure to post some pics of it installed :thup:
1972 F250 Custom LWB
1999 F150 Ext Cab
2001 E350 15 Passenger Van
70_F100
Re: Dash inserts
Post by 70_F100 »
Check out Robroy's thread on his gauge setup:
http://www.fordification.com/forum/view ... =3&t=44449
roughneck
Re: Dash inserts
Post by roughneck »
70_F100 wrote:Check out Robroy's thread on his gauge setup:
Thanks for the link. I'll have to wait til tonite after work to read through it, but it does look a lot like what I want, except I am still on the fence as to wheter or not I want a tach. :fr:
red403
Re: Dash inserts
Post by red403 »
I am going to use the metel gauge bezel and make my own insert as I want to have speedo,tach,volts,fuel,trans temp,water temp,oil temp,oil pressure,2 vents for the a/c,signal lights,high beam,brake light. I have it all set out how I want it just need to get the last few gauges then start to cut the holes in the insert. I am going to be using 2 1/8" auto meter pro comp gauges. The speedo will be the metric one with a tach the same size as I am from Canada.
dailyf100
Re: Dash inserts
Post by dailyf100 »
Here is how I did mine.
roughneck
Re: Dash inserts
Post by roughneck »
dailyf100 wrote:Here is how I did mine.
[ Image ]
[ Image ]
[ Image ]
[ Image ]
[ Image ]
Thats a beauty!
