door lock
uncletee52
door lock
Post by uncletee52 »
i have a 1972 f100 and the door lock just falls down to the lock position. i would like to know how hard a job this is to do, Also who has these parts. thanks a punch
BobbyFord
Re: door lock
Post by BobbyFord »
More than likely the spring broke on the latch. A latch is relatively simple to replace. Pull the arm rest, inner door handle, window crank and door panel. Then unclip and remove the handle and lock rods from the latch, remove the three phillips-head screws holding the latch to the door. Reverse procedure to install. If you have the soft door panels it is best to use a door panel tool to avoid tearing the clips out of the fiber board.
72BahamaBlue
Re: door lock
Post by 72BahamaBlue »
I think this spring has broken.
