so over the past week now, my dad and i have been redoing our '69 f100's u joints and carrier bearing. but yesterday, while pressing the u-joints, the cap got locked up and then shot into the yoke so hard that it cracked. if anyone out there can help me out with this in any way, i'd really appreciate it. what i need is a 16 spline slip yoke for a '67-'72 truck with a 5.9l V8. i'm not really sure if the trans matters but it has the borg warner t18 4 speed. please, any help at all would be greatly appreciated.
-sam
does anyone have a drive shaft slip yoke?
- samericsson67
- robroy
Re: does anyone have a drive shaft slip yoke?
Good day Sam,
I believe you'll probably find a nice used yoke from another forum member. Yet should that not come to pass, here's some info on an alternative.
A few years ago I wanted to adapt my T18 transmission to a 1350-sized universal joint, while installing an upgraded driveshaft in my truck.
A guy named Marcelino (I think) at Inland Empire Driveline (in southern California) made a custom yoke for me! He did it quickly and for a good price (I forget how much), and his product was beautiful. Also, he made it out of forged steel.
If you were to mail your cracked yoke to Inland Empire Driveline, they could fix you up with a replacement.
On the other hand, for all I know, the yoke you're looking for is an OEM part that can be bought new from any driveline shop. Actually, if you're still using the factory universal joint sizes, that's almost a certainty.
Robroy
Robroy
- Ranchero50
Your location is?
Simplest fix will probably be rumaging through your local junk yard engine or driveshaft pile.
Jamie
Jamie
- samericsson67
thank you. i'll bring it up with dad. but i believe you about it not being available at any new shops. i've tried 3 and looked on a bunch of online stores. i'd like to make it to a junkyard this weekend but i'm not sure if i'm going to find anything. out here in Pennsylvania things tend to rust fairly quick. but thanks for the help though. i'll be sure to check it out.
