No Neutral 4 speed 68 F-250 2wd
Hi I am new to this site and this is my first post i recently put a new clutch in my 1968 ford F-250 2wd 4 speed and when i drop the transmission i did pull the shifter off after getting it all put back together i do not have Neutral. Did i put the shifter in wrong or did i put the clutch plate in backwards please help thank you!
- 1972hiboy
Re: No Neutral 4 speed 68 F-250 2wd
I did the same thing back in high school. You can pull the shifter out again and make sure your getting it inbetween the shifting forks but otherwise it may be the clutch disk on backwards. It would not release and act like you have no nuetral.
Rich
Dont eat yellow snow.....
Yeah im thinking its the clutch cause i can spin the output shaft by hand when the truck is off but when its on i let the clutch out and it spins i can go threw all the gears just fine so im stumped!
