I have a NP 435 with married transfer case from a '72 F-100. What is involved in removing the t-case and using transmission in a 4x2?
Will
NP 435 question.
- HIO Silver
Re: NP 435 question.
IIRC, 2WD NP435s have a different front mount pattern - square vs trapezoid as used on 4x4s.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
You need to swap output shaft and find a matching tail housing. You also need to find speedometer gears.
mmerlinn (http://mmerlinn.com/catalog/makeridx.htm)
"People who are careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Steven Raymond
