72 F250 C6 Trans Speedo Cable Gear Cover
I am going with a GPS speedo and won't need the speedo cable anymore. I am wondering if there is a cover for the place the cable mounts to the transmission. I removed the cable and would like to cover the hole.. is there a cover made for this?
Jim
1972 F250 390 C6 "Rusty"
Re: 72 F250 C6 Trans Speedo Cable Gear Cover
You can use almost anything to cover the hole, even the old speedo housing without the gear attached. Or you can go to Ford and buy a plastic cover used on lots of transmissions in the late 90s.
mmerlinn (http://mmerlinn.com/catalog/makeridx.htm)
"People who are careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Steven Raymond
