Tranny swap t-18 to c-4 or c-6
Sunwings
Post by Sunwings »
1969 f100 has the T-18 3 speed + granny. I am looking to swap out the t-18 and do a temp replacement with a c-4/c-6 tranny while the other will be torn down and rebuilt.
The tranny will be bolted up to a 300-i6 . I am not worried about the linkages/brackets or the cooler. that is taken care of. what I need to know what do I need to do to swap out just the transmissions.
I know about about changing the the flywheel to flex plate.
I do not know if I can use the same cross member and drive shaft. This is a daily driver and I do have a good c-6 tranny here and a c-4 that I can use if i need to.
the next thing I do not know if I can use the same 2 piece drive shaft that I have.
Later on this truck will be restored to its original state.
Any help would be appreciated.
one last thing , were would be the best place to buy a rebuild kit for the t-18? new bearings, and bushings?
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
Whateverman
Re: Tranny swap t-18 to c-4 or c-6
Post by Whateverman »
you'll need an auto trans starter, and the front half of your driveshaft shortened if you can't locate one from an automatic truck
you can use the existing trans x-member and the tranny mount
Sunwings
Post by Sunwings »
thanks for the info , this what I needed to know. 8)
Whateverman
-i should add that you might have to move the x-member and drill a couple of new holes in the frame,but that would be pretty obvious when you got that far along
Sunwings
Post by Sunwings »
well I will not be doing that. I did decide to have a friend take out the old tranny and we found the problem were the front bearing housing was loose. it tore up the main input shaft . so now it is time for a rebuild.
