Posi Rear End
JWTurner1951
Posi Rear End
Post by JWTurner1951 »
For you all in the know, what does it cost to convert a 1972 F250 from non-posi to a positraction rear rear?
cdeal28078
Re: Posi Rear End
Post by cdeal28078 »
Depends on what type you are installing and if you are doing the work yourself or not.
I just went from an open 3.0 gear to a 4 pinion 3.5 gear. I had the case and gears. I paid a local well known builder to install HIS 4 pinion differential and my gears. He set it up. I took him the gear so I did the work off pulling and installing. I have around $200 in it. It is not a "posi" but a 4 pinion. It will spin both wheels most times IF both are on the same type surface and the tires are the same and have the same amount of air in them according to the guy that built it. I am very happy with the set up. Something to think about. It is also supposed to be a very strong system.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
HIO Silver
Re: Posi Rear End
Post by HIO Silver »
JWTurner1951 wrote:For you all in the know, what does it cost to convert a 1972 F250 from non-posi to a positraction rear gear?
Your rig has a 9-inch?....About $450-$500 plus labor.
Btw, the term "positraction" or "posi" is a Bowtie term. We blue oval boys like to say "Traction-Lok"
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
sargentrs
Re: Posi Rear End
Post by sargentrs »
I installed one of these. http://www.richmondgear.com/powertrax/noslip.html Around $500 + labor to reset ring and pinion. While I had it torn down I replaced all the bearings and seals for another $100+.
Kurt Combs
Re: Posi Rear End
Post by Kurt Combs »
A 72 F250 should have a dana 60 under it, are these prices appropriate for a dana?
Kurt
1972 F-250
sargentrs
Re: Posi Rear End
Post by sargentrs »
The PowerTrax has variations to fit either at the same price.
