72 F250 Missing C6 Part
JPC1972
Post by JPC1972 »
Can anyone tell me what this piece is called and maybe how I can get it if it is needed? My Tranny is a C6
Jim
1972 F250 390 C6 "Rusty"
71PA_Highboy
Re: 72 F250 Missing C6 Part
Post by 71PA_Highboy »
looks like the speedo hole...
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
BobbyFord
Post by BobbyFord »
It looks like mine. You need the type of speedo cable that plugs into the trans (with the speedo driven gear attached) as opposed to the screw-in type. I've seen two types of extension housings on the short rear shaft trans: One has the speedo cable connecting with a screw-in type cable on the passenger side of the trans, with the speedo driven gear attached to a plug that stays with the trans when the cable is unscrewed and the other has a plug-in style speedo cable on the driver side of the trans where the speedo driven gear is clipped on to the end of the speedo cable and plugs into the extension housing and is secured with a cable-attached bracket and a 1/4-20 bolt.
JPC1972
Post by JPC1972 »
Thanks guys that is exactly what it is.. i took it off about a month ago and forgot I had done it.. been looking for a cover for that since i am going gps.. i gotta slow down with taking stuff off lol!
Jim
colnago
Post by colnago »
JPC1972 wrote:i gotta slow down with taking stuff off lol!
I've found that a digital camera (even a real cheap one) is invaluable to have when removing stuff. I never know what's going to interrupt my project days, and how long it will be before I get back to it.
Joseph
JPC1972
Post by JPC1972 »
Joseph
Hey Joseph not only do i photograph everything with my phone I bag and tag everything... it's the only way i could ever do this and be able to put it back together.. :)
Jim
