Dana 60 inner axel seal?
montanahighboy
Post by montanahighboy »
I recently began to notice what appears to be differential fluid leaking around the rear brake drum on one side of the Dana 60 full floating rear on my '68 F-250 highboy. Is this an inner axel seal or could it be something else? Thanks in advance.
averagef250
Re: Dana 60 inner axel seal?
Post by averagef250 »
Hub seal. No seals inside the axle. Front axles have inner axle seals, rears do not.
montanahighboy
Thanks, I was looking at the manual wondering about that. Should be an easy fix.
71PA_Highboy
Post by 71PA_Highboy »
Put a speedy sleeve on it while you are there.... it will save you TONS of issues down the road.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
