Hey everyone,
I am having issues with my clutch and am wondering what I need to do to fix the problem.
I had the clutch replaced at a shop cause the old one wouldnt shift well anymore, pedal to the floor grinding gears to shift etc.... So I replaced it.
Pedal was at full swing and it felt awesome. Not a month later, the pedal is back on the floor. Wth??
Called th shop and he said it could be the linkage or the shift fork. Is there anything else it could be?
And I am no hotrodder so I know it isn't burnt up
Clutch help 67 F-350
- Archinto
- basketcase0302
Re: Clutch help 67 F-350
Here's the clutch linkage schematic, maybe it will help. Can you crawl under the truck and see if the linkage is loose and if it's engaging the fork going into the bellhousing?
- Archinto
The linkage is tight and in contact with the fork.
- sargentrs
Check out this thread and see if it may be your issue. http://www.fordification.com/forum/view ... ot#p387682 I had the same problem and fixed it the same way.
- Archinto
Hmmm, I'll have to check that out and make sure the fork is set correctly. I am going to play with the adjuster screw and see if that'll bring my pedal back up. As it is, there's barely enough to shift into gear from a stop.
- basketcase0302
That would normally be the case in my expierence with our old trucks.I am going to play with the adjuster screw and see if that'll bring my pedal back up. As it is, there's barely enough to shift into gear from a stop.
