What is it.
How's your Ford truck parts knowledge?
69Ford
What is it.
Post by 69Ford »
What is this found on a dash voltage regulater.
fireguywtc
Re: What is it.
Post by fireguywtc »
that looks like the electric "choke" that is attached to the instrument panel voltage regulator (IPVR). The newer ones, 70-72 I think, have the 9V battery style connections on them.
Bill
1970 F-250 4x4 highboy ranger 390 V8, 4spd
2012 F-350 PSD FX4 LWB CC lariat, white
http://www.fordification.com/galleries/ ... hp?uid=602
"If you want to judge a person's true character, give them power."
Superjunk
Re: What is it.
Post by Superjunk »
What does it do?I installed a new regulator and my gauges would only work without it.
68 F250 390 4 speed 4x4 flatbed dually dump
97 F350 Crewcab 4x4 7.3 Powerstroke auto
91 Bronco Nite edition
79 Bronco 460 c6 1 tons 42s wheelin rig
79 F250 4x4 plow truck
My Supermotors page,http://www.supermotors.net/registry/3845
gilc
Re: What is it.
Post by gilc »
Constant Voltage Unit?
flyboy2610
Re: What is it.
Post by flyboy2610 »
It's a disgronificator. Your truck won't run without it. :D
TheEskimo
Re: What is it.
Post by TheEskimo »
Poking around online with the part number, it seems to be a Radio Resistor Suppressor Choke. Used to suppress electrical noises from the engine to the stereo. Don't know why they were put there instead of near the radio wiring, but they seem to have been more common in vehicles with AM radios rather then the AM/FM.
-Jason
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
kf7mjf
Re: What is it.
Post by kf7mjf »
They were probably put where they were because that was the noisiest part of the wiring as far as the AM radio was concerned.
1967 F-100 Ranger
samericsson67
Re: What is it.
Post by samericsson67 »
it's that resistor that goes behind the inst. cluster. i've blown so many of them but i dont know why. i've tried to find a short somewhere but failed.
69Ford
Re: What is it.
Post by 69Ford »
I just took it out and run without it.
1969 Ford F100 Styleside standard cab 360 C6
