Guys i am sure this is one of those ones that i just havnt found a previous thread or faq on so if there is one please point me to it.
I have a 71 F250 4x4, i want to put either HP Dana 44 or Dana 60 (depending on what i find first) with disc brakes on it.
Is this a direct bolt on or do you have to weld new perches on or outboard the springs?
Sorry i know this is one of those beat to death ones and i'm just to dumb right now to find the information.
Rob
Install of 78-79 axle?
- KRob
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
- michael69
Re: Install of 78-79 axle?
not sure if the 4x4s are the same,but on the 2 wheel drives the spring mounts has to be move out about 2 inches on each side because the 73-79 axle housings are 4 inches longer. Also the springs are wider so you have to use the spring pads off your truck on the newer housing. But like I said don't know if the 4x4s are the same.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
- michael69
Also you may get more info on this if you post it in the 4x4 and off road section also.
Michael69
- KRob
Thanks,
I just put a second post up to double check. I kind of remember that there a direct transfer but it i am not sure. and its bothering me that i cant find it on the internet.
Rob
Rob
- KRob
Thanks, question was answered on http://www.fordification.com/forum/view ... 01#p629901
And yes its a direct swap. The if you use a low pinion you dont have to change drivelines but since im going with a mated 205 the high pinion should make better geometry.
Once again i felt like an idiot asking and not being able to find the answer.
Rob
Rob
- basketcase0302
I've owned and worked on our trucks, (bumps/dents/Broncos/BII's/Rangers) for over 30 years and still have to ask questions.Once again i felt like an idiot asking and not being able to find the answer.
Rob
- michael69
Michael69
- KRob
Thanks guys....i just know how annoying those dumb always asked question are that can be answered with a little searching and reading.
Thanks for the understanding.
go for 60 look for # 610023-1thru 6 change MC and prop valve,get crazy it will take it.
